what do yll think of trick flow heads
Musturd
But I've seen cars make 330rwhp with all supporting mods bolt ons and long tube with a nice custom tune
Venom351R
Maine
that all depends on if there was a correction factor used or not. I never have my corrected numbers advertised as my actual power I'm making. Corrected numbers are what it would make in ideal perfect conditions (humidity/elevation) well guess what, if you dont live in that area then your car does not make that actual amount of power. I'm not saying its impossible, but I see it as a long shot for a regular H/C/I package making over 320 even with a custom tune. Long tubes would be a nice bump but there would have to be a custom cam thrown in there for me to believe a car put down that much w/ out using correction factors.
cobra head
cobra head
Onyx im just going by what the guy said from crane cams he gave me that part number and said that the cam he gave me the part number to is called the cobra cam reason y its called the cobra cam is bc its works really wel-l with the intake aswell as the cobra computer
Weird, I'd consider a Cobra cam the came that comes in the car. Either way just wanted to enlighten whoever, the main thing is the specs given for the crane 2031 are with 1.7 rockers.
cobra head
cobra head
no big thing what i was saying is the cobra cam by crane its called that bc it works well with the computer like other cams that dont unless tuned
I don't think so... there are a lot of cams like that, they are called computer compatible and they're for all 94-95 cars.
rz5.0
Great state of TEXAS
I never bother to compare them but I've heard it called cobra cam I figure it was like the rockers were also crane but are also cobra rockers.
itsblue95
Louisville Kentucky
id say you will make around 300rwhp. With my setup AFR 185cc, TFS1, Holley systemax intake and all the supporting mods i made 310/316 with my injectors messing up though. you cant go wrong with those heads as ive heard a ton of good things about them.
Teal94
Knee deep in the water some where
Great heads! Custom cam and ditch the cobra intake(unless your gonna port the crap out of it) and you will get there.Had a set of TW's on one of my old cars running an Edlebrock intake,70mm throttle body,1.6 rr,and long tubes.Cant remember what cam I was running. 5 spd with 4:10 gears and could run 12's all day. Never got numbers on it,was poor and could not afford dyno stuff back then. Should break the 300hp mark with a good tune.
