what to look at when buying a shortblock
5.0kid
I blew my engine the other day (threw a rod i think) so I'm looking at buying a new shortblock. There is a shortblock I'm going to look at tomorrow, a 347 with all new machine work and the stroker kit is also new. What all should I look for when buying the shortblock?
5.0kid
yes, but there is one built locally that i'm looking at, its a lot cheaper than that and i can get one tomorrow.
Spd0lit
SoCal
is it brand new never run? if they let you have a look at the bottom end and maybe look under a main or two. have it rotated to see it will turn smoothly.
2slo95fiveoh
Lawrence, Kansas
X2. You might even want to bring some of your own tools to check it out. feel the cylinder walls for any scoring,
maybe bring a flashlight or something to check out the oil passages.. etc...
5.0kid
well, i picked it up today! he had all the paper work for all of the work done to it and it was EXTREMELY clean, even the clearance for the rods. Should be putting it on the engine stand tomorrow and will be getting to work on it soon. I'll post some pics also.
LAFENATU
What are the specs on it and how much was it?
Ie: what kind of block/crank/rods/pistons/compression?
5.0kid
stock block, cleaned and bored 30 over and honed. also had a line honing done to the main caps and all the plugs replaced.
then, it had an eagle/keith black 347 rotating assembly put in, balanced by eagle, and I have the serial number and balance numbers on a card also. It also came with a new balancer and flexplate (i have a manual, so i'll be still using my flywheel).
kit included eagle cast crank, forged i beam rods, and hyperteutetic pistons which should be around 10.2 compression ratio with the ported windsor sr heads.
here are some pics of whats going on the engine. I'll be using ported windsor senior, a ported typhoon intake, and a trickflow stage 1 cam with 1.7 rockers (i really liked that cam when i had it in my 302, and i will change it out later down the road for a custom one).
sorry again, i need to get something other than cardomain, these pics are huge.
LAFENATU
Wait to install it until you can get a cam. The TFS stage 1 cam is not going to do much for you. That is a cam for a 302, not a 347. If you do the job twice your going to have to buy new pushrods etc.
Do the job once mang.
How much was it?
5.0kid
$1000 and im installing it with a 1.7 rocker set up. I just need to get it running and don't have the money right now for a custom cam...
Spd0lit
SoCal
be sure to find out what balancer and flywheel they balanced it to. Because stock is 50oz. and i recall alot of strokers use 28 oz.
5.0kid
is the 351 flywheel a 28 oz, or 28.2, i can't find it online...some say it will work
