what tranny oil ?
4point6GT
royal purple ATF tranny fluid or Synchromax manual tranny fluid ???? as you all kno I will be installing my new clutch soon. My car is a 98 so does anyone know if my car specifies an automatic transmission fluid,motor oil(ATF tranny fluid ) or if it is recommended and requires Ford Mercon® or GM Dexron® III transmission fluids.(Synchromax manual tranny fluid ) ??? please :help2:
ANG
95% sure you use the ATF tranny fluid - i know its wierd how they tell you to use auto fluid even if its a manual
4point6GT
thanx angie....I will get ATF when I put in new tranny oil in. will I need a lil more than 3 qts if I flush tranny like u need with the synchromax tranny oil or will just 3 qts be good enough ?
4point6GT
OH SHIT!!!!!!! i just realized i fucked up..... :hammer: my bad......... i mixed them up LMAO!!!!!
suppose to be- recommended and requires Ford Mercon® or GM Dexron® III transmission fluids-ATF tranny fluid
- car specifies an automatic transmission fluid,motor oil- Synchromax manual tranny fluid
my bad, hahahahaha........ok so which one do I use again ?
ANG
really you can use either one.... mercon type is the ATF fluid, but syncromax is specifically designed for manual transmissions that require auto tranny fluid..... go with the syncromax (better shifting power)
ANG
thats what we are talkin about .... syncromax royal purple for manual transmissions :bunny3:
St33da
Fluid - M/T
Notes
NOTE: Use the following Ford recommended fluids or an equivalent meeting the applicable Ford specification.
ATF Transmission Fluid, MERCON Multi-Purpose
Part No. XT-2-QDX
Specification Mercon(r)
Willis_98GT
DFW Texas
yeah i was actually going to flush my fluid whenever i change my shifter...
royal purple syncmax isn't good??? i want to know what will stop my grinding. god it makes me so f******g mad sometimes... seriously.
smasher41
pennzoil scychromesh :thumb:
my notchy 1-2 shift is gone, put 100 miles on the car since changing fluids, I love being able to tap 1 finger agiast shifter to get into gear!
sk8inrj1
How do you flush a manual tranny? I have a T5 if that makes a difference.
T's Convertible
