when it ain't broke........
D3VST8R96GT
Marble Fall, AZ
uncltrvlnmatt said:
ttocs said:
SUCCESS! went fishing with my grabber and got it! I bought that grabber last (where you push the botton and the four pins extend from the end)week when I dropped a bolt that I could see and was just out of reach and it has saved 2x already. Highly recomend it if you do not have it as I use to use it all the time to run wires with as well.
That is a abortion tool, it is not supposed to be used to pick up dirty parts.
hahahaha
if you can pick up aluminum on a steel frame with a magnet you are a better man then I, and can walk on water too....
if it is to you then like I said you are special, or your aluminum is special. No it is not magnetic.
Dalamar
SLC, UT
I've had days like that.
makes you want to throw something!
keep at it man.
how goes round 2?
had too much crap to finish it up, I hope to later tonight. I was able to get that fitting on completely so hopefully I can remember how to put everything together and be ok.
Like I said though the abortion tool is great for running wires, and grabbing things you can't even see.
I will post pics when its done.
