where can I get a fuel pump for my 98?
JDwhite98gt
Ok so I know I can go with a SVT focus pump, vortech or Aviator pump, but can I use an 03/04 cobra pump? I need a somewhat cheap replacement and Ford wants over 400 dollars for an OEM replacement which is just crazy. I really dont need any room to grow as far as fuel goes so a stock 98 pump would be best for me as long as I can find a cheaper alternative other than going through the Stealership. Would NAPA or Pep Boys carry a pump? Any other suggestions?
sneaky98gt
I don't know about new or aftermarket pumps, but I got my SVT Focus pump for $75 used. They normally go for about $100 used and will leave you plenty of room to upgrade in the future. Is a direct replacement as well: take the old pump out, drop the Focus one in. That simple.
lordgufi
if you have returnless you can get a walbro 255 built for a 99+
if you have a return system you can use the ones for the 96-97
I believe for the return systems you can also use the walbro 255 for the 99+ reguardless of the fact that they are vari voltage pumps
J
JDwhite98gt
Not looking to spend anymore than 150, so used would be better. I'm not going to run a walbro pump because of my budget and also seen through searching the site that there is too many conflicting stories. I have a return system with a vari voltage pump and all other pumps I heard requires me to hardwire them to a constant 12V source...I dont want to do that. If I have 2 lines comming into my fuel rail it means I have a return system right? lol
greenscobie86
The Big Apple
I have one laying around from my 98GT... Its fully dressed with the sump and float and everything... The previous owner said he replaced it about 10k before I bought the car off him..
I'll do $45 shipped?
greenscobie86
The Big Apple
OEM Motorcraft pump, sump, floater,strainer... pump had 15 or 16k since it was replaced by the PO...
Its ready to go.. Just need to put it in a box with an address on it.
J
JDwhite98gt
ok I'm PM'ing you after this post. Going to include my cell # and we can talk over the phone if you're cool with that.
