Where to get a speedometer calibrator?
pooker
Ok I am not sure if that is the right term so dont laugh at me, I have never owned a rwd car , my 95 mustang gt has 3.55 gears in it, it hurts me everytime I drive it to see more miles put on it than it has. Can anyone point me to a place that sells a new speedometer cable or something that readjusts for these gears? I am not sure all of what I would need, thanks for the help. :TY:
SMOKEDURVTEK
I have the same gears and felt the same way... Get a speed cal from dallasmustang.com My speedo is right on the MONEY!!!! The instructions suck tho... If u have questions about it PM me.
P
pooker
Hey thank you very much SMOKEDDURVTEK , I went on that website and found what I was looking for, but I have one question, in the description it says fits 94-98 mustangs then under that it says 96-98 ? I guess I better call them huh, how hard is it to install and where do I install it? Is it pretty much plug and play I dont wanna get in over my help. :help: :)
CanaryGT
Phoenix
Hey Pooker, It will fit the 95 cause I bought one from them and I have 4.10's and it fixed my problem. The reason why it will work with the 94 and up is because of the way it gets sent to our gauge. You basically just kinda have to make your own wire harness from the stuff they give you and it fits right in.
SMOKEDURVTEK
It was'nt two bad to do.. Just take out the center peice around your shifter.. Then there are 4 bolts there to take out. Then disconnect your battery and and unplug the ci lighter. Your gonna want to tap into that wire with the wire tapper connectors they give you. It will tell u what wires to use. They have instructiions on there site. Also Your gonna have to take that red wire out of the case and u can cut it down also, you dont need more then 8 inches. Also u will have to check the diagrams To set your calibrator for the right gears. You just open the little black box and you will see what im talking about. INSTRUCTIIONS will help a little. ha, Good Luck!
