Where to pour seafoam to all cylinders?
ctaylor_369
Hey all, I'm new here. Ive been doing maentenace on my 94 v6, and these forums have helped me a lot, so I figured I'd finally make an account. Anyway, I've been wanting to seafoam my car, but I'm not sure exactly where to pour the stuff. I heard the pcv hose works well, but do I take the hose off of the actual pcv valve? If so, when I follow that hose there's another hose connected to it, should I disconnect that before seafoaming? Sorry, I've not been doing this for very long so I'm still learning a lot. Pictures would be great. Thanks for reading.
whiplash473
Northern IL
Seafoam's website would probably say. If I remember right, you throw half in the gas and half in the oil.
I think it depends what part of the engine you want to clean with it. I thought for combustion chambers you unhooked a vac line and let it suck it up.
LilRoush
In your TV
This.
Pull a vac line off the upper intake and let it draw it in there. It will clean the upper/lower intakes through your valves and inside the cylinders that way. Just a heads up, your exhaust is going to puke out some NASTY stuff, so be ready for a big smoke show afterwards.
lutter94
South Dakota
You have to regulate the flow, otherwise it will try to die. After you get rid of the whole can, let it sit for a half hour. Then start it up and rod the piss out of it. It will have thick smoke about 40 yards wide 40 yards tall for about 2 blocks......Don't do it at your house if you live in town......i always blew it out while driving....
[video=youtube;X832d4MtYUc]http://www.youtube.com/watch?v=X832d4MtYUc[/video]
Slykin
Tyler, Texas
I'm still not convinced I want to do this to my car... Seems like a bad idea.
GT3FC
Phoenix, Arizona
i'll pour a full bottle into a vacuum line, it doesn't really matter which one just pour the bottle into a vacuum line (try not to pour too much and kill the engine) leave it off for 10-15 min then start it up (probably hesitate to start but eventually it will start) then enjoy the smoke show.
DeepList
Administrator
Admin
Auburn, IN
I used SeaFoam on my old sixer pretty frequently. What I usually did was put ⅓ of the can into the oil and ⅓ of the can through the air intake using the brake booster line. I'd let the car sit for a few moments, then start it up and drive it around for a few miles. Then I'd go to the gas station, dump the remaining ⅓ of the can into the gas tank and then top it off with fresh gas. After that, I'd go back home and change the oil.
There's really no set directions or way of doing it.
DeepList
Administrator
Admin
Auburn, IN
Dose it really work
Some say yes, some say no. I think it does, but not really to the extent that people tend to believe.
I think that a lot of the "gains" people say they receive after doing it are due to the placebo effect.
DeepList
Administrator
Admin
Auburn, IN
It won't hurt anything if you did. Just don't expect it to be a "miracle in a can" like some people tend to be believe.
Barner1
Tennessee
I think that's the effect it had on me
IDTag
