which cam to go with....
Canary95GT
Trickflow stage 1 or the comp cam xe274......I can get a stage 1. Pretty cheap...this is for a set of worked gt40p heads ...
IVXX
I am actually wondering about this myself, I was debating the TFS Stage 1 cam as well, any input from anyone?
beuchaw94gt
Ive heard the TFS-1 works well with gt40 heads. I currently have the combo just havent had any time to do the swap yet. If you do a search there is lots of topics about this.
I have been considering a stage 1 for some time but wondered if there is that much difference between stage 1 and stage 2?
C
Canary95GT
So lets say I go with the tfs 1 ... I found a nice used set of 1.6rrs. For 90 bucks...said they have 500 miles on them....what's the advantages and disadvantages of 1.6 vs 1.7 rockers....I have to use 7/16 stud mounted ones...
Rice_slayer
If you use the TFS1 with 1.7rr, you MIGHT have to notch the pistons. I heard some guy JUST had enough clearance without notching, but what works with someone might not work for you. Check PTV clearance first, I know for a fact stage 2 NEEDS notched pistons to be used, or else I would have gone with it ;).
BigTang
what heads are you running to have 7/16 studs? If it came w/ those you shouldn't even consider running that shitty of a cam.
Stage 2 cam is too big for stock heads. yes, GT40's are stock heads.
You need to upgrade the springs to at least the $100 trickflow spring kit.
Always run 1.7 rockers when you can, they help with valvetrain stability.
Always check PTV, its easy, use a checker spring and the converted lifter, the lighter spring will let the valve drop farther giving you a bigger recess than you actually need.
C
Canary95GT
gt40p heads...........previous owner had 7/16 studs installed and isky guide plates....
BigTang
Good luck finding a 1087 and if u do and dont buy it let me know I'm still looking for one a tfs stg 2 is similar but softer off the line.
Keep looking for the 274. It's killer on the dope.
Win
Kennesaw, Ga
I just Picked one up 135 Shipped :)
i am hoping to run it with a 1.7 Crane RR of a Cobra :)
