Which intake manifold?>
stang4u2nv
Hey guys i'm planning on buying an intake manifold for my 94 gt but i got stock heads for now which intake you suggest. i'm thinking about the holley systemax and or victor 5.0 or trickflow track heat and suggestion on a throttle body? thnaks a lot. >:D
ga94gt
I would say go with the Trickflow, if you went with the holley you would loose a good bit of low end tourq.
fast5oh
i just did my trickflow track heat with a 1 inch spacer and a 75mm bbk and it is awesome
Downshift
Depends on your plans. If you are gonna keep it pretty stock then no matter what you get the heads are gonna restrict it. I think the best would be the edelbrock because of looks and performance out of the box. And the removable side plate for easy access for porting the upper further.
Factory Freak
I agree with 5.0wned. The Edelbrock rpm 2 looks awesome... and yeilds some great gains. It looks better than the track heat.
CobraCop95
I personally like the new BBK 5.0 Intake, but if you don't want to spend that kind of money, i would go with an edelbrock performer or a systemax
stang4u2nv
i have decided on the performer rpm 2 as it sits in the middle of all intakes and you what they say peak numbers doesn't yield you a fast car but middle range and across the rpm range does make your car move faster so. I think it is a good choice plus it looks friggin awesome. thanks guys.
