Which Motor Oil Do You Use
Mustang68
ya forgot the "other" selection in the poll...
everything on my stang is motorcraft... oil, filter, ect ect..
truck gets whatever's cheapest... usually it gets castrol..
realitygt
i used a fram filter once. idk how an oil filter could affect how your engnie runs but it did. it ran like shit.
Jrgunn5150
Mobile 1 5w-whatever with an OEM filter for whatever it is going in.
Royal Purple is better, but Mobile 1 is more easily accessible for me.
trav_19
RioRed96GT said:
tRaV_19 said:
well synthetics are not for everyday vehicles...
they are i didn't explain well i guess.... if you have a car and maintenace is not your thing and its not up to par and you just start running synthetic in it ...your going to have issues and those are the people you will find that bash synthetics....if you only knew the amount of times we sold a synthetic oil to some farmer john or whatever and he said ..thats stuff done junk ..it done made my engine leak...yada yada yada....
i was trying to explain that ......most vehicles that are just dd's done really need synthetic either
Petek
no one else runs amsoil huh??. Ive also heard that fram filters are complete shit.
ryclef331
Rotella-T 15w40 Full Synthetic with a Wix Racing filter....
....yes I run diesel truck oil in my car. If it can hold up to 10k of abuse from a heavy hauling diesel truck, its good enough for my needs!
realitygt
they redline at 3500 rpms tho.
ryclef331
and pull 15k lbs of weight. and run under 48lbs of boost on a MILD application. Whats your point? I don't do it b/c its just some "hunch" that I came up with. Ask around...you'd be surprised who runs and reccomends it. We run it in our shop's 1,000+ hp supra as well.
Shocker98GT
^x2
New EPA regs mandated a large reduction in ZDDP (Zinc Dialkyl Dithio Phosphates) because as an engine wears out and consumes more oil, the burnoff of zinc and phosphate could potentially damage catalytic converters. Boo freaking hoo, so the emissions a-holes decided that ZDDP had to be substantially reduced in regular motor oils. BTW, ZDDP is your main anti-wear, anti-corrosive, anti-oxidant additive in oil . The reason that guys are puking so many bearings and valvetrain components nowadays (especially guys with flat tappet cams, etc.) is because they've substantially reduced the PPM of ZDDP.
Diesel oil, however, still has these additives and this is why lots of performance guys are using it. Add the fact that Rotella T is dirt cheap, and it really is win-win. Amsoil is one of the few oils on the market that still has a good amount of ZDDP in the additive packs.
ryclef331
^x2
yeah...what he said.
My engine builder says run it and I take his word for gospel....so I do.
Jrgunn5150
seriously, my dad uses it in all our truckc and equipment. We just had a Dodge with a CUmmins hit 800k
Petek
maybe when my pap's goes to change his oil in the international, ill get him to pick up a few extra jugs.
ryclef331
its cheap too! I get it at walmart by the gallon! 4 gallons for the truck...and 1.5 for the car.
