wideband install help
94-5.0GT
i bought an aem uego wideband. first question where should i put the bung? on the long header or in the h pipe? i know to put on the driver side cause cylinder 8 run the leanest. i plan on keeping it in the stang for awhile til i get my turbocoupe done
Paul
The instructions will typically advise on sensor location. It will typically be near a collector, with a maximum specified distance from the exhaust ports. I had a dual wideband, and had both of the on the "side" of the pipe (to avoid moisture) about 6 inches from the header flange if I remember correctly. However, I'm old and senile to take that for what it's worth.
Paul.
modo
Philadelphia, PA
paul is right on the location...
in my experiences with my motors (forced induction) cylinders 7 and 8 are the leanest... but you won't pick that up on the wideband as it is the average of the entire bank.
Paul
Nope. Don't bother. I did it because it was overkill like the rest of my stupid car.
Paul.
Adam95GT
Paul.
Not overkill, really handy for tuning and diagnosing issues
Best gauges to have IMO are:
Oil pressure
Water Temp
Vac
Wideband
Trans temp (If auto)
Paul
For the overwhelming number of users who don't tune their own stuff, it's overkill. I had it because I had an AEM with dual-channel widebands so my buddy could tune the car. I'm the major exception, not the rule.
Paul.
