Wierd noise. Help?
SVTgoose
I hear a loud howling/grinding/squealing noise when i am rolling at a very low speed. It happens when i am NOT applying the brakes. If i start rolling forward, it will make that noise and soon stops after i pick up speed. Same thing happens if i am rolling slowly at a very low speed, even in neutral. Im guessing it is a wheel bearing considering it happens when i am not using the brakes. Any advice would be great.
SVTgoose
not really, it's coming from the front it only happens when i am going straight at like 0-5mph.
SVTgoose
It doesn't make the noise when turning, i actually just drove it a couple minutes ago trying to figure out what it was and it didn't make the noise at all. How ever when i turn the wheel left all the way it sounds like something is grinding against something. I have steeda front sway bar and end links, maybe that's an issue with clearance? That only happens when i turn the wheel all the way to the left, doesn't happen when i turn it right.
