Will this headgasket set fit?
STNG_96
Hey guys, haven't posted here in forever, but I am thinking its about time to start messing with the mustang again. I haven't actually driven it in two years.....that aside, here goes.
I still have a top end from an 04 GT needing to go on my 96 GT. I have a buddy who wants to do some porting on the heads before they go on, so I need to get a headswap kit for a couple things he needs. My question is, will this kit work?
http://cgi.ebay.com/ebaymotors/2001...r_Truck_Parts_Accessories&hash=item3ca45a472a
I was under the impression that I could get a headswap kit for a 01-04 GT, and I would be good to go, can someone let me know if there is something completely different about this kit, or is it just that one small thing is different. I am guessing that I would have the basic intake/exhaust/head gaskets that are the same, but I just am curious.
Thanks!!
dirtysnowball302
go on jegs or call jegs an ask for a cylinder head change kit from ford racing...if you say i want a pi head swap gasket kit he will talk to you like your retarted...i know lol. it has everything you need for that swap. an its multi layered steel gaskets so there real good
STNG_96
See, the problem is, the ford racing kit does not come with new intake gaskets, and this kit I have linked above actually has quite a bit included.
duff daddy
The kit you linked is JUNK, HANDS DOWN JUNK!!! Do not buy aftermarket, no name brand gaskets!!!!! Go to ford, tell them you want a head changing kit. This will come with everything you need, then tell them you need Intake manifold gaskets also. If you need part numbers let me know I will get them for you. Ford has some of the best gaskets out there. I'm using STOCK head gaskets for an engine with 13:1 CR, hell every gasket in my engine is directly from the Ford dealer. They are your life line, they keep you dry, sealed and quiet, don't buy junk gaskets.
STNG_96
Ok, guess Ill just get one of the ford racing kits, and by the intake gaskets separate, thanks
cmher18
+1 Don't cheap on gaskets. My HG alone are $120 my cost...
