winter plans list
93PGT
so i have decided what i am going to do. i will buy pi heads. and i will buy cams. like a street/strip cam. i will buy a high stall converter and a performance valve body. then i will drop the engine/tranny from the bottom and swap everything over. then i will have it tuned that way my pi intake will bolt up perfectly and i aready have 4:10's and on the 15th, i am hoping to run the car to see what kinda times i can get
does this sound resonable? or are ther better ways to make power tell me please and give recommendations on brands and anything else
97stanger
why put stock pi heads on your car? I would get a nice p/p job done as well. Other than that, you will definately pick up some good power. It will feel like an animal with the converter too. I would definatly look into some suspension/sticky tires :thumb:
93PGT
i am aready set on my suspension. and i have slicks as well. the cams are comp cams 278's -SOHC-Street/strip, needs higher gear ratio (i have 4:10's), 2400+ stall. Intake (like a cai?), exhaust (i have LT's and full exhaust), computer upgrade required (i assume that means a tune). Rough idle. i think that might be what i want
96GTPlanB
