Worth upgrading to 3.73s?
HuskerGT
Nebraska
Since my GT was originally an AODE car it came with 3.27 gears. I am going to be swapping out the rear brakes with a Ford Racing Cobra brake kit that requires pulling the axles to install the brackets for the calipers this Spring. Since I'm going to have the diff opened up anyway, will upgrading to 3.73 gears be noticeable enough to justify the cost of the new gear set, install kit, etc?
Thanks
2v_takeover
Saskatchewan
Usually people suggest 4.10's with the auto's I think! For the money, I think it usually reigns supreme on the 'bang for your buck' discussions.
yes it's worth it imo, that is if you don't think the 3.27s are enough. I went from 3.08 to 3.55 and it was quite a nice change. If you're going to add a power adder though 3.73 might be too much.
Slykin
Tyler, Texas
I think for a non daily street/strip car 3.73's are fine.. though I personally am not a huge fan of mine for DD status. I like to travel a lot, and the 3.73's rev too high at cruising speed for me, plus 1st gear is basically useless without real good tires. They do give a nice pick up in acceleration though, I will admit that.
vermilion
maryland
i don't see how 3.73s on the highway rev too high. driving @ 70MPH, my engine is revving 2200 RPM. i have an aluminum flywheel and driveshaft. i simply dont see this logic. With the STOCK driveshaft and flywheel it was @ 2400 or so RPM.
Saint
At 70 mph I'm at about 2400 rmp...not too bad...It is a pain talking on the phone people think I'm at a race trak or something
I have 3.73's in an auto....the mpg suffered a bit...still happy....they pull so hard
No bs I've pulled on vette's audi's and other high end car's 3.73's make a world of difference
At about 70mph roll you'll have no pull so don't go racing some supped up civic unless you want to get walked
50mph roll the tires nearly break loose....And thats not even flooring it by they way
Musturd
I have no problem racing from a roll arm nitrous purge floor it ;)
3.55s with a 26" tire and .68 OD i'm turning 2400rpm at 75mph, in my opinion that's a bit much but then again it's all what you're used to. with the stock 3.08 it turned 2000rpm at the same speed.
and how the hell does changing a flywheel and a driveshaft affect your RPM?
Saint
+ 1
After awhile you won't even notice you're at 2400rpm at 75mph
Just put them in and you won't regret it, may even get a speeding ticket or two:mad:
Musturd
2400 is nothing at 2000 rpm the car is gutless and super quiet . I don't mind driving 300 Miles on the highway with my car anytime
JerZeyStangz
Northern NJ
Aode here with 3.27 factory stock to 3.73's. I honestly think they rev really high. It's kind of weird to say, but reason why I think this is because the modular motors start making power around 3k, and your almost right there, so it constantly sounds like your ready to mash the gas before a race, but at cruising speed if that makes any sense. The reason why I wanted 3.73's is because its being swapped to a stick soon, so I wont have to worry about the rearend not lacking gear.
Nacho98
Note the OP is doing a 5-speed swap. I've got 3.27s with a 5-speed and it's just barely over 2000 rpm at 70. Anything higher for a DD I'd be kind of ehhhh, since it starts getting over 2k at 75-80 mph. Are you DD'ing the car?
uncltrvlnmatt
Pa.
I have 3:73's. Pull about 2400 @70-75mph. I would do it again. My mpg did not suffer enough to worry about. Still getting 20-22mph with 187k on the clock.
The alluminum flywheel and drive shaft give less rotational mass. Don't know if it will turn less rpm, but it will get there quicker.
Musturd
Isn't 80 mph speeding pretty goood there ? 3.73's on my 96 gt are great on the highway the speed limit here is 100kph so 60mph ... In 5th its usually lugging the car way to much with stock ghetto gears ... I'll never own or drive a dogged out stock geared car again. My new vert is getting gears before I do anything else to it
Nacho98
Most freeways here are 70 outside of the city (there it's usually 55-65), and I think there are a couple of 75ers. 80 is a good clip though, but sometimes you just feel like a pimp in your 225 hp turd.
H
HuskerGT
Nebraska
Thanks for all the input. I did my 5-speed swap about 6-7 years ago. Mine isn't a DD since I put it away for winter, but I do drive it quite a bit in Spring & Summer. From my research, the rpms at highway speeds with 3.73s won't bother me that much. 2400rpm @ 70mph isn't anything to worry about, imo
Next question: Should I spend the additional $$ and get the master install kit that has the bearings etc? My GT has around 60k on it now
