Yay! I broke down today! HELP PLEASE!!!!
LaserRedSVT96
well, as the title states, my cobra and i ended up on the shoulder this afternoon on the way to school. im not sure what the problem is exactly, but i think my fuel pump took a crap. here are the details on what happened:
-car shut down when letting off throttle stopping at a red light a mile from breakdown point.
-car started back up unhesitantly and continued fine another 1/4 mile.
-car lost nearly all pedal responce, as if i ran out of gas (car had 1/8 of a tank)
-car shut off and would not start again.
-i coasted to a stop and tried to start 5 or so more times, all resulting in barely making 300rpm and shutting off.
-i checked to make sure connections under the hood were ok. everything seemed fine.
thankfully 5 minutes after this happened, a stang buddy of mine drove past a noticed i was broke down. like a pal he turned around and came to see what was wrong. we then went to a dealership his mom worked at and got a gas can, just in case my gauge was wrong. put a gallon or so in the tank. nothing. then he noticed my fuel pump wasnt making the ever-noticable fuel pump prime noise. we checked the fuel pump fuse and it was fine. the car was towed to a buddies shop where ill drop the tank first thing in the morning. even better, the tow was free (another buddy). can anybody confirm or give any guesses on what the problem is? the car has 107,xxx miles on it.
my car picked a perfect day and time to break down, because my phone is broke and i broke down in a BAD part of town. in other words, id still be pushing it home now if i wanted all windows and parts there in the morning if my friend didnt pass by.
mich_666
Ouch man thats rough... it kind of sounds like the fuel pump. Check your fuel pressure!
Hoseitdown
May have trash in it, if it only had 1/8 of a tank... BUT, I could be wrong...
2slo95fiveoh
Lawrence, Kansas
Fuel pump does sound like a very likely cause. I was pretty sure that our cars have a fuel pump relay, in which case
if you replace the fuel pump, then I would recommend replacing the relay at the same time. Try to see if you are getting power
to the fuel pump with the key in the "on" position. Or, if possible, use a powering test light to see if it will cycle.
mich_666
+1 on that as well, cant hurt.
Yellow94gt
Sounds like the stator in the distributor to me. That's exactly what my car did. It would shut off and I'd coast to a stop... I would restart it and it would run for a few minutes, then shut off again and it would stay dead for awhile and then it would reset itself and start again. There's a tiny little 20 dollar part in the dizzy that needs replaced and I haven't had a single problem since then.
assuming his user name being laserredsvt96 would lead me to believe he has a 96. therefore no dizzy. good guess otherwise. i don't know much about you obd2 guys but it might through a code.
L
LaserRedSVT96
well guys i found the problem. the power wire shorted the pump out. apparantly when i changed the filler neck grommet, i pinched a wire and partially exposed it. somehow it didnt do it until now. maybe it just was pinched and got rubbed or something. if i didnt have the car on the lift i probably never would have saw it. note to self. glad it was a cheap fix.
