1995 Cobra Upgrades
kb1982
Kentucky
Its been awhile since ive been active on the forums. Just thought I would post up about what i have been doing to my 95 Cobra. A big round of upgrades are in the works. The biggest change is going to be an all new top end. New heads, cam, lifters, rockers, pushrods, intake, injectors, and throttle body. Im shooting for 650 hp at the tires on e85, so a new fuel system has been planned also. The shortblock is a dart sportsman block 347, with RPM H beam rods and forged 3.4 zero balanced crank, with Ross pistons for TFS heads. With the new heads, Im ended up with a CR of 9.8 to 1. Should work great with the Vortech V2 Si supercharger.
Just an old pic of the car.
DSCN0735-1 by kelly benningfield, on Flickr
Out with old....
CameraZOOM-20170329183442631 by kelly benningfield, on Flickr
CameraZOOM-20170330113223918 by kelly benningfield, on Flickr
CameraZOOM-20170330115050330 by kelly benningfield, on Flickr
And all tore apart. Looks pretty clean!!!
CameraZOOM-20170415205813625 by kelly benningfield, on Flickr
One cylinder had a little damage to the old TFS Fast as cast 170 heads. Looks like preignition but didnt find any evidence on the corresponding piston or ring lands.
CameraZOOM-20170415191525961 by kelly benningfield, on Flickr
And now for the new goodies. TFS 205 11R heads
CameraZOOM-20170425083802057 by kelly benningfield, on Flickr
CameraZOOM-20170425084706257 by kelly benningfield, on Flickr
Custom Ed Curstis hydraulic grind cam .601 intake and .603 exhaust lift with 286 and 300 duration at.006
CameraZOOM-20170508131834233[145] by kelly benningfield, on Flickr
New 7/16 Comp Cams 1.6 Ultra Pro Magnum Chromemolly rocker arms.
CameraZOOM-20170430195824111 by kelly benningfield, on Flickr
Switching over to Morel link bar lifters
CameraZOOM-20170519192618088 by kelly benningfield, on Flickr.
Ill keep this thread updated as more parts arrive and more work gets completed.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Hey man, good to see you around. You were here in and out when I started to come around. Im glad to see you back around though.
Her name is Jaz
That's freaking sweet man, watching this thread!
Sent from my XT1585 using Tapatalk
evilcw311
Most Evil Member!
Louisville, KY
Real life problems right there........
kb1982
kb1982
Kentucky
Car parts, motorcycle parts, and tools. At this point,hookers and booze would be cheaper. An unfortunately, more are on the way lol.
Sent from my Z962BL using Tapatalk
kb1982
kb1982
Kentucky
I like the crimping tool with interchangeable jaws.
I still need to get the die to do spark plug wires with. The premade sets always come up to short to route in a clean manner.
kb1982
kb1982
Kentucky
Not much has really happened with the project as late, but things are going to start happening shortly. Was shooting to have the motor back in the car by August, but the Box R intake is on backorder until 8/13. Waiting on the new timing chain to arrive then work will commence. Will be installing the custom FTI cam, degree it, check ptv clearances, measure pushrods, bolt the heads on, and mark the lower intake for port matching with 1262R gaskets. In the meantime, gonna make a few bucks using my new toy...Autel Maxisys Elite scan tool.
Stay tuned to see what's in store for the fuel system. Its gonna be nice.
kb1982
kb1982
Kentucky
Got a few more pieces of the puzzle delivered today. New timing chain with Torrington bearing, new valve covers, and some 95 LB hr Deatschwerks injectors. The parts list shrinking thankfully.
kb1982
kb1982
Kentucky
Got the new Accufab 90mm throttle body in a few days ago. Still waiting for Trickflow to make the black powder coated Box R upper that it will mount to.
kb1982
kb1982
Kentucky
Well TFS finally made the upper. Had to sit it all together just for giggles. I also found a great deal on a Procharger "Big Red Race Valve " so I couldn't resist. The Bosch valve was mediocre at best. The fuel system and odds and ends are the only parts left. Well with the exception of pushrods.
kb1982
kb1982
Kentucky
Finally started some assembly today. Got the FTI cam installed and degreed, new timing chain on, measured for pushrods and checked piston to valve clearance. The morel linkbar lifters got dropped in and the heads sat on. They still need to be torqued, but I should be able to finish that tomorrow, along with the timing chain cover, water pump, and harmonic balancer.
kb1982
kb1982
Kentucky
Made some progress today along with some setbacks. I had the timing cover and harmonic balancer on, but broke a water pump to timing chain cover bolt. My efforts to extract it proved futile, so decided to switch efforts the top end. Got the new pushrods installed, along with adjusting the comp cams 1.6 ultra pro Magnum roller rockers. Moved on to the valve covers, and then the TFS Box R intake, and lastly the 90 mm Accufab throttle body.
kb1982
kb1982
Kentucky
Got a little more work done today. Got the replacement timing cover on, the water pump, the Innovators West balancer and timing pointer, accessory and blower pulley, and the new oil pan on. Of course once again, ran into problems. Either the oil pan or timing chain cover was a little to proud in the front seal area, not letting the front of the pan to seat far enough down. The Ford racing one piece gasket got the front seal cut off, and replaced with a nice bead of the right stuff. The rear seal was left intact, but also got some right stuff love. Instead of welding a -8 an oil return on the pan, I decided I would try a bolt on fitting from jegs. For anyone needing an oil return in the pan, I would recommend one of these. https://www.jegs.com/i/JEGS/555/522...uv5PGms7f1bm6Q9VjPeZdck3TH0V2v_hoC8qgQAvD_BwE
Srchop16
