Anybody using H&R Sport springs?
Tillerman77
Southern MN
If you do, can you post your thoughts about ride quality, how much you scrape, if you have ISOs installed and photo(s)? I am specifically looking for Sport photos and impressions, not for the SuperSport.
I am considering going from stock springs to these next season, using poly ISOs along with Bilstein HD struts and shocks. CC plates will also be installed.
Car is a 97 Cobra, used for spirited driving but no track use. Roads are a mix of smooth to rough. I already have MM FLSFC welded in along with a MM 4-point K-member brace. Bilstein shocks and quad shocks are already installed. As mentioned above, Bilstein struts will be done during the spring install.
DKblue98GT
I have pretty much the same setup you are planning on only my car is a convertible. I have the convertible brace which hangs pretty low under the car. Full poly iso's.
The air deflector usually scrapes first but I have to be careful on rough roads.
On a coupe you should have good clearance. The ride is stiff but the handling is very good.
Sent from my Pixel 2 using Tapatalk
Tillerman77
Tillerman77
Southern MN
Just to clarify, are your springs the Sport or SuperSport from H&R?
Tillerman77
Tillerman77
Southern MN
From the H&R website - should be a part number listing for all of the SN95 and New Edge Cobras. Coupes are the first 3 images, followed by convertibles. Now you can check the part numbers on your springs if you care to.
Subtlebeast
Central NJ
I am running H&R sports with poly isolators. I think it will be a tough comparison since I am running Tokico Adjustable drag struts for a fox body in front, J&M weight jacket LCA, J&M uppers, with no quads. Adjustable Tokico illumina shocks. Car is not a corner carver. Ride quality is good.
Srchop16
