dyno #s
98GTSTANG
ALITL8 said:
98GTSTANG said:
I put down 196RWHP and 266RWTQ the other day. Allright for 71000 miles. Was hoping to break 200 though. Mods are listed below.
add an o/r h-pipe and you'll be there. i put down 203.2 rwhp 279.6 rwtq with my 97 and the mods listed in my sig minus the pullies. my o/r h-pipe is just a stock pipe with the "6" cats removed. also, when i ran on the dyno i had 157,000 miles on it ;D
I am looking at doing a PI swap right now. Just need to find a good deal on heads and an intake. I was just going to do the cams and intake, but labor is only about $100.00 more for the heads.
98GTSTANG
ALITL8 said:
PI intake and heads $325
http://www.okdhm.com/forums/showthread.php?p=486023#post486023
he hasnt contacted me about splitting up the set. all i need is the heads, ive got a brand new PI intake in the garage
I can't get in without a password, but let me know how much he wants for the intake. Just made a deal for romeo heads, $300.00 shipped with cams. Romeos are the heads of choice from what I have read.
Car2n
223 rwhp / 267 rwtq
stock 1997 V6 with a Procharger.
ALITL8
i'll PM him and see what he wants to do. where are you located?
98GTSTANG
San Antonio, Texas.
ALITL8
i PMed him... we'll see what happens. i decided against the heads since they came off a windsor :dunno:
blackfang
Only dynoed once.
8/2004- Car had K&N, Mac o/r h pipe, Magnaflow dumps, 4.30 gears, bad o2 sensors and a stock tune
273/263
blackfang said:
Only dynoed once.
273/263
have you done anything since that dyno run?
AmericanStang
here is what i am hoping i am around, 245 - 260hp/290trq.....just had a full system fluid flush, running straight synthetic with K&N 63 series air charger and flowmaster 40 series with h-pipe. running on premium, and a timing advance resistor chip...increases timing about 2 degrees...and reads colder air on computer and makes the fuel supply a lot more lean.
281powered
what do you think my car would pull on a dyno with the mods in my sig? and what would that convert into at the motor for numbers. i was guessing 215 rwhp/ 270trq or so?
blackfang
Snakebit said:
blackfang said:
Only dynoed once.
273/263
Sorry I forgot about this thread.
Yes. Replaced the bad o2 sensors, FRPP wires, new plugs, Longtubes, o/r x pipe and a JMS tune.
98GTSTANG
Matt94GT said:
that sounds like a good estimate to me trq mabye a bit lower?
I think your tq will be a little higher than that. I am running 266rwtq and the only big mods I have is flows, 3.73's and a KN filter. rwhp sounds about right on. I pulled 196. Your PI cams should give the extra boost.
ALITL8
im sure i posted my dyno sheet in this thread. i had everything in my sig except for the pullies when i dynoed. with my 390's i made 179.6 rwtq. i'd think you'd make a little more hp and tq with the PI cams. get it to the dyno and find out... let us know :thumb:
281powered
thanks guys for the info :thumb: and ALITL8 i love the pic of your car on the dyno with the hood up, looks bad ass! do you have any othter pics of it, i would like to check them out?
ALITL8
281powered, there are pics posted all over this board. Member Rides section i believe :dunno: i have some older pics from last year before i changed the wheels but theres a good one of under the hood... its all stock but clean ;D http://www.autodetailin.com/mustanggt.html
Denunzio36
Just had my 95 GT dyno tuned and chipped yesterday...best pull was 230 hp / 273 Fpt....It was chipped because the computer was messed up..idle poorly, rpms came down slow, etc. It came out pretty damn good...Here's what is in the car...Let me know if you guys think it pulled well.
Trick Flow Street Heat upper and lower intake
MSD distributer and coil
70MM Throttle body
73MM C&L MAF
24lb injectors, FPR, 255lph fuel pump
3.73 gears
The technician was pretty impressed what it made considering there were no major mods done to it..What do you think?
Addermk2
im hoping to be right around 230-240 whp and 270-280 wtq... but you never know
1994 Ford Mustang Cobra
Flex Honed Upper and Lower Intake Manifold
BBK Equal Length Headers
BBK O/R X-Pipe
MAC Performance 2.5" Pro Dumps
MAC Performance Cold Air Intake
Professional Products 70mm Throttle Body
Ford Racing Parts Underdrive Pulleys
Ford Racing Parts Suspension Package
Granatelli Motorsports Rear Control Arms
Deep Dish 17x9/17x10.5 Black Cobra R Wheels
RevJon
