Tired of my shocks, i think?!?
Vengeance
Orange, CA
So i bought this car used a few months ago (about 7) and the previous owner put some bran new shocks on before he sold it to me (Tokico D spec) and i dont know if its the shocks or the Eibach sportlines but the suspension is to stiff for my liking.
I had another mustang prior to this that had lowering springs (dont know what brand) with kyb gr2's and i loved it.
Should i try to sell the tokico's and get some kyb's, or is there another shock you can recommend that will be soft for the crappy California streets that wont break the bank.
OR should i save my pennies and get a nice set of coilovers? Or will thoes be just as bumpy? (i had a set of coilover on a SRT4 neon and the thing handled awesome but was bumpy as shit)
Leaning towards the kyb's though
Vengeance
Vengeance
Orange, CA
should probably mention that, the rest of the suspension is stock, but i am riding on 18in fr500 with falkin rt615's.
I would make sure you know what springs you have. Are the D-Specs adjustable? IIRC, they are.
Find out what's on there 1st, 100%. I would go with a set of progressive rate springs, nothing stiffer than 650ish in the front if you end up changing springs.
And I may be interested in those D-Specs if you end up sellin'. :)
95riosnake
Pittsburgh, PA
Might be a dumb question, but have you tried adjusting the shocks? D-specs are adjustable...you just have to have an adjustment key.
Orange 94
Alberta Canada
I have D spec tokico's on mine. They are adjustable but it makes a very minor change to the ride, mostly only makes a difference on the track. I'm not sure if its the tokico shocks since ive never had anything else but my ride is extremely stiff. But personally I like the stiff ride, i dont find it too uncomfortable.
I think its pretty hard to have a smooth ride once you start lowering it and upgrading the suspension. If you've had good luck with kyb's you should try them again.
Slykin
Tyler, Texas
Sportlines are actually the same as the stock spring rate I believe, just shorter. The problem is that they have little travel left, and you may be hitting your bumpstops. If you're NOT hitting the bumpstops, your shocks/struts are probably pretty stiff.
Vengeance
Vengeance
Orange, CA
RichV: the springs are sportlines, and yes the shocks are adjustable :) i would gladly sell them to you but that would require me to ship them and shipping is ridiculous cost wise :(
95riosnake: i have adjusted them, and it helps but still kinda uncomfortable.
Orange 94: you are right, the lower you make the car, the lower the comfort level. Do coilovers offer a better ride quality with the lower height?
Slykin: I dont hit any bumpstop, so the shocks are pretty dam stiff, not as bad as i have been in, but still pretty bad.
Orange 94
Alberta Canada
I have no experience with coilovers. They suppose to be an improvement for performance, but i have no idea what the difference in comfort would be.
I'm sure theres someone on here if you keep your eye open that can give you a good review on coilovers.
Vengeance
Vengeance
Orange, CA
Its just the springs man.. swap them out for the H&R super sports. Theyre progressive and ride really well. The tokico d specs are an awesome shock and strut.. So i would definitely hold onto them.
You can always get the coil over kit from MM for those shocks and struts to..
http://www.maximummotorsports.com/s...e=product_info&cPath=514_2_78&products_id=507
hey thanks man thats pretty sweet, so you think its the sportlines that make my ride so stiff and bumpy, a set of progressive springs will make the ride softer. i will look into that. thank you
Slykin
Tyler, Texas
Coil overs do help with ride.. i'm running really stiff coil-over springs up front and it still rides decent. They're not budget minded though.
Vengeance
Vengeance
Orange, CA
On American Muscle, it says sport lines are progressive, maybe when I have spare cash I will get thoes mm coilover conversion kit since I have tokico already
Cpotts13
Biloxi, MS
hmmm my bad. That would be the best route though forsure
Suprasuavy
