I still can not figure out for the life of me how to get the stupid sway bar back on (It's off of a Fox, but it worked fine with my stock lca's...)
Anyway, I'm having a huge banging sound come from the rear when I go over bumps at speed especially on the freeway, and on a couple roads with major potholes. It is clearly coming from the rear, and my thought is that the arms are still not long enough to properly articulate over the more entire range of motion.
The arms are currently oriented at an upward angle (because my car isn't lowered, I'm assuming), and it seems like tech says that the watt's arms need to be parallel to the axle, and that the cradle needs to be perpendicular to the arms. Right now the cradle is perpendicular to the ground, and the arms are simply long enough to make that possible.
So question of the moment is: Should I make some measurements and put the arms to the length where they *would* be perpendicular to the cradle when they are parallel to the ground, or do I have it set up "right" since this is how my car normally is?
