Will These Wheels Fit ?
lutter94
South Dakota
Increasing offset pushes the tire closer to the center of the car. You would probably need spacers. If they actually do clear everything and bolt on, they would look strange tucked in and all......The steering would probably have major issues.
I might be blind but where do you guys see the offset in that ad?
5-oh-MUSTANG
Canada, Ontario
Lmaoooo. I just noticed. The " +44.0 " was the area code for the seller. :laughing4:. I thought that was the offset. But regardless it came off a 350z. Those offsets are much different than ours.
Here's the specs on the wheels:
OEM 17″ Alloy from Base & Enthusiast models from ’03 – ’05 (17×7.5 30mm / offset 17×8 33 mm offset)
With a small spacer they will fit just fine.
Mysticcobra
