01 gt bogging down ???
blsticms1
ive got a 01 gt with auto trans . about 3 weeks ago i noticed when i would floor it then it would bog down for a few seconds and then pick up . i cleaned the maf , tb . replaced the plugs , coils , pcv , iac , tps and fuel filter . ive got new o2 sensors to go in with a h pipe . it shows no codes , and i test drove it after each step listed aboue . the only mod to car is a cold air intake . what am i missing . it ran great before and just did this all at once . please help
duff daddy
The parts you repalced, did you use factory motorcraft parts or aftermarket???
duff daddy
eh, I wouldnt trust those to fix it. Normally, ignition parts and sensors are FOmoCO only in my book. Personally if those check out ok, I would start to either data log with the xcal or look for vacuum leaks or loose hoses under the hood before i spent money needlessly on parts.
B
blsticms1
ill check vac hoses first . this mod motor stuff is all new to me . im alittle lost . ive never had trouble useing parts from aftermarket on any of our cars so im not sure if thats it or not .
duff daddy
Mod motors arent much different then a pushrod. Just think, if you had this issue with a pushrod, you probably wouldnt start with an aftermarket autozone cap rotor and dizzy ....
