I have some 03-04 cobra injectors 24 lb. I was wondering if i could put them in my 94 gt, i know the harness is different, but i was thinking of gettin the new harness plug and adapt it to work? I also will need a MAF. Is this possible.
94GTcobra said:They are blue so im guessing they are 24lb. Weird.
RJayLo said:Where do you live? Or maybe I should ask whats the altitude of the track you ran at? IF you are at a higher altitude NA cars pull off slower times than those closer to sea level.
I just say this because our track is 5800' which tends to equate to nearly a full second off from sea level times.
stang4u2nv said:03-04 snakes came with 42lb injectors, now the lightnings were equipped with the 38's for some reason. dark blue are 38's and green top are 42's and the plugs are the same they should fit without issues and yes you need a new maf or a tune.
