11” Clutch pressure plate bolts
Rolltide1006
Hello all. I am upgrading from a 10.5 to an 11 inch clutch and have found out the pressure plate bolts are bigger. The 10.5 pressure plate bolts are grade 8.8 and I was wondering what grade I need to get for the 11” setup. Thank you for any help/advice
Sent from my iPhone using Tapatalk Pro
Stock flywheel?
Its possible the clutch bolts may not be metric. Take the flywheel to a hardware store and figure out what size bolt it is.
I used socket head machine screws. Sorry tho, i cant remember the size, but the grade was over 8. Most likely grade 10
Sent from my SM-G900P using Tapatalk
Rolltide1006
Rolltide1006
Stock flywheel?
Mcleod steel flywheel
Rolltide1006
Rolltide1006
Stock flywheel?
Ya the stock 10.5 plate bolts are 8.8. I was thinking of going to ACE and getting the same grade if not better.
Thats a good idea. And if you need to modify the bolt length, just be sure they are close to the same weight
Canaryonvskf’s
