18x9 wheels hitting swaybar
mustangsel
Hey guys I have 18x9 wheels and when I turn the wheel all the way they hit the swaybar :dontknow:. I've heard that there is a spacer you put in the inner tie-rod. I'm coming up with a loss though. Have any of you ever had this problem?
Ninety8stang
Duh405
You can put a small wheel spacer on the front to help out with clearance. You can pick them up at your local parts store for around $20. I fairly certain Mr.Gasket carries any size you need just make sure you go with one that wont effect your lug bite. 1/8th-1/4th should probably do the trick. My dad runs them on the front of his cobra with no problems at all.
mike97gt
Red Deer, Alberta, Canada
my 275's up front rub on the sway bar but in 30,000kms they havent shown any wear in that spot. rubbed the paint off the sway bar but didnt show any wear on the tires.
TACTICALGLOCK
SOUNDS LIKE YOU HAVE THE WRONG WHEEL OFFSET. I HAVE 18X9 ON THE FRONT OF MINE WITH NO PROBLEMS.
