1995 Ford Mustang Gt with 357W
95boss351
[/IMG]
[/IMG]
[/IMG]
Up for sale is a 1995 ford mustang gt. It has a non-roller 91 351w block that has been bored .030 over, making it a 357.
I won't list everything that is on the vehicle, but i will list the main components.
357w with a balanced and polished stock 351w crank. I believe its cast
Engine: Less than 5k miles
Stock 351w rods thts been shot peened and has ARP studs
Probe Forged Aluminum Flat top pistons with valve reliefs
TFS Stage 2 cam
Retro fit hydraulic roller lifters
TFS Twisted Wedge Heads
PP Upper and lower intake.
PP 75mm t/b
Anderson motorsport 76mm maf
Ford Racing 42 lb/hr injectors
+more
Transmission/Drive Train: Less than 10k miles
Worldclass T5
Ford Racing Heavy Duty Clutch
UPR Clutch cable Firewall adjuster
Nodular Iron Flywheel. Forgot the brand
Steeda Tri Ax short throw shifter
Ford Racing Aluminum Driveshaft
Motive Performance 4:10 gear
Suspension:Less than 10k miles on Front, Less than 2k miles on rear
Tokico Front struts
Tokico lowering springs all around. 1.25 in drop
Strange 10 ways rear Shocks
MM Tubular rear upper and lower control arms
Steeda C/C plates
Subframe connectors, Forgot the brand
Power Adder:
Nitrous works t/b plate kit. 85-175 shot
This is the bulk of everything, but there is alot of other extras.
The car has been professionally tuned at alternative auto. I have the dyno sheet.
Car put down 312 rwhp and 315 rwtq. Without Nitrous. Has not been tuned for nitrous.
Numbers are low because it was tuned for reliability and drivablility.
HAve not been able to take it back to the track to see what it runs now, but previous run was 13.3 at 106 mph with a 2.3 60ft. w/o nitrous
With a 1.8 60ft, this car can easily see high to mid 12's without nitrous. with nitrous, Definitely low 12's high 11's.
The car has been recently painted, but the job was poor.
Im asking $8,500 for it, but i am absolutely open to offers. Also Including 2 extra black bullitts rims with no tires
If you have any questions, feel free to give me a call at 248-505-1764 My name is Brandon or PM me The car is located in Southfield, MI 48034
95boss351
thanks i appreciate it.
Also letting everyone know, car has BBK 1 3/4 longtube headers, Custom cut MAC o/r h-pipe and original 40 series flowmaster mufflers
Musturd
With ur mph you can get it down pretty nice
RevJon
