1998 gear ?
Sn95Willis
Baytown Tx
I was looking up the 98 Gt info and it shows tohave either 2.73's or 3.27s.. How can I tell what the car has in it???? Or is there a way?
BigTang
rpm @ 70mph?
3.27=2000
2.73=1700
which is probably useless because my stock tach is all over the place compared to the autometer
karrarararararar
there's a tag attached to the differential cover by one of the bolts. If you have 3.27 then it'll say 3L27 if you have 2.73 it'll say 2L73
karrarararararar
hey, if it is 2.73's then at least it will make it feel like a bigger improvement when you swap them out. My 96 had 3.08's and 3.73's felt a lot better
GDawg
Your car's an auto right? So I'm guessing you have 3.08. Otherwise the manuals had 2.73s unless they got the "gear option" which would have put the manual at 3.27 like mine.
Jrgunn5150
The question is a moot point, no matter what, it's not enough.
At any rate, hopefully by now the tag is gone, or you have a 20k mile creampuff... Bigtangs calculators are the best bet.
justinschmidt1
my auto had 3.08s...the axle code on the driver side door will tell you what it is...
E is for 3.27s
Z is for 3.08s
M is 2.73
I believe 3.08s were standard so thats most likely what you have.
Sn95Willis
Sn95Willis
Baytown Tx
K thanks.... Well my 4.30's will be going in the 14th.... And mayat the track the 15th, if not the folling friday for sure....
ninety7_four6
another way to do it if the tag is gone and say maybe you cant drive the car, lift it up in neutral,mark the tire and spin the driveshaft. if it takes 3.27 rotations of the drive shaft to rotate the tires once then you have a 3.27. you just have to keep a close eye bc obviously 3.27 is about 3 and 1/4 turn
96GTPlanB
