King.kold_
- Joined
- Jan 4, 2019
- Messages
- 3
- Reaction score
- 1
How hard would it be to swap from 2v to 4v?
Sent from my SM-G970U1 using Tapatalk
I would have to replace a lot more parts on the sohc block though right? What parts would I need to replace?How hard depends on your skill level.
Its simple to obtain the parts nesasary. How difficult is it for you to do the work depends souly up to you.
Heads, matching intake manifold, exhaust manifolds, valve covers, front chain cover, head gaskets, intake gaskets, head bolts, injectors. Mount the heads. Set the cam timing. Run engine!
Its easy talking about it! I wished everything was has simple as talking about doing it
Some electrical connections are not same if I remember correctly
also the head combo 96-98 you need the spacers for the intake or the intake runners and control box for them
I think sometimes your better off getting a complete engine with all the connections on it .
Are you taking it down to the bare block and rebuilding itHere's some pics
Sent from my SM-N950U using Tapatalk
What do you need as far as 4v parts maybe I can helpI'm using a extra block from a 4v I had laying around. Its fully rebuilt to stock 4v specs. Though I will be using a bunch of 2v parts as I dont have all the 4v ones.
Piddly stuff some I'm going to fab up or just go aftermarket.What do you need as far as 4v parts maybe I can help
