3 miscellaneous questions...
Daryl
Somis, CA
1. How do you remove the Mach 460 speakers from the rear deck lid?
2. Is the “Cobra” badging only on the front calipers?
3. Is the proper size lug nut socket a 13/16” deep socket?
thanks!
white95
Apex Junky
Admin
Prairieville, LA
thanks!
1) Not sure
2) Yes, the rear calipers are the same for V6 and GT’s also.
3) That is correct.
get on your back in the trunk and look at the bottom of the enclosure and there are 4 holes that go up into it. Its been 20 yrs since I pulled mine so you will need to check the size but probably 9/32 screws/bolts.
01yellercobra
To add to number 2..... the brake pads are different between the V6/GT and Cobra due to the thickness of the rotor. Not too much of an issue when putting Cobra pads on a GT, but makes it a pain if trying to put V6/GT pads on a Cobra. Happened to a couple guys I knew before.
Daryl
Daryl
Somis, CA
Stroke of luck... I found a deep 3/8” socket just laying by the spare tire in the trunk well. Fits the blacked out aftermarket lug nuts
Result!!
