4.6 to 5.0 modular build??
97Bullitt
El Paso, TX
Been long range planning.
And not wanting to go too crazy, and plan on a budget....I've been looking at these:
4.6 Aluminator: $4300
4.6 Romeo Iron Replacement: $799
And comes the point I was looking at
5.0 Boss Block: $1299
Now I don't know much about the modular world.
I know that back in the day a 5.8 build/swap uses many of the same parts off a 5.0, which made it really easy.
But on this?
I would assume the top would be the same.
But what about the internals?
I would assume since the bore and such is different, would I need different (possibly very expensive) internals?
Anyone ever do a 5.0 mod build? or know someone who has?
If it works, it'd be a bit of a sleeper, a few extra ponies more than anyone would suspect.
And I haven't heard of alot of people doing this. So it would(at least to my knowledge) add to originality.
duff daddy
You could go that way. Or you could get a set of PI heads, bigger cams, PI manifold or other. Take a good nitrous kit and go from there a little 75 or 125 shot and youll be more then happy.
If you want to go with the 5.0 kid thats fine but you will have money in that rotating assembly. A good friend of mine took a 4.6 nvh block and went up to a 5.3 so it can be done but again like you said, how much money is too much.
97Bullitt
97Bullitt
El Paso, TX
Like I mentioned the internals seem to the the expensive part.
it has 4.6 deck height, so at least it would fit, but from there, even by comparison, it'd be easier to do a 5.0 stroker.
I'm gonna keep looking into it. Just gotta find the internals, that will be the ultimate decider.
vermilion
maryland
its not cheap. 2300$ for rotating assembly and extra 400-600 on machining the block. you can use your existing 2v block. i went with a WAP block. again, its not cheap. please think your build through. Call the companies and not search the interwebz for answers.
97Bullitt
97Bullitt
El Paso, TX
i called down at texas hot rods over around El Paso, cause that's where I am heading.
WHOA, even getting the parts together myself, OUCH.
When the time comes, even with the costs of finding supporting mods, looks like a pushrod 5.0 may be finding it's way in.
GrnGt
Have you looked into Ummm or whoever else sells shortblocks? Then you could just reuse your top end
97Bullitt
97Bullitt
El Paso, TX
looked at modmax, seemed tempting.
been reading that the 5.0 strokers maker better torque, but could actually lose out on HP
McCloud
Johnson City, TN
I did a Boss 5.0 block with stroker rotating assembly. The big bore stroker rotating assembly was only a couple hundred more than the stock bore stroker assembly but the block is costly. Only reason I went that route was because I was deployed and could afford it.
97Bullitt
97Bullitt
El Paso, TX
Well since I'm deploying soon anyway, that is another reason I was debating this.
I read about the boss block capable of holding far more power than I ever plan to throw at it.
It is either a 5.0 block or when I rebuild, I'll put a stroker kit in it.
That said, I don't wanna blow all my deployment money on the car. Gotta pay off debt for when I get out.
I'd say I am on a tax return budget.
3-4 Grand.
That said, if the block is good, then 5.0 stroker, with PI swap. Nothing crazy.
Looking for about 300RWHP, and longevity.
vermilion
maryland
i deployed and wanted the treatment. i had everything done except swapping the engine myself with a friend.
97Bullitt
97Bullitt
El Paso, TX
UGH, still looking.
MMR's 5.0 shortblock looks promising, that with the trick flow top end kit, the track heat intake, and a bit more aggressive cams....
looking that direction.
or just getting forged internals...with the trick flow stuff.
Im pretty much sold on the heads :)
Willis_98GT
DFW Texas
Yeah you really cant go wrong on the head choice..
do you plan to build all of this yourself? or a shop?
you can budget this easily, modmax has awesome deals on stuff and you can find teksid (strongest) blocks for sale all the time for cheap and have a shop throw it all together
97Bullitt
97Bullitt
El Paso, TX
probably going to let HPS in el paso do this.
As I am going there next.
I'm really not after much.
I just want it to last a while.
97Bullitt
97Bullitt
El Paso, TX
Yeah it is, considering the trick flow top end kit alone is 3G
I would still need a PI intake.
But a friend of mine here in germany has this setup, along with alot of other things, but he still has the sheet in his project binder of the top end kit.
+122 HP
so you think about it.
215+ 120(+)
Thats a nice boost, putting the motor in the 300 range.
Granted when I do this, I'll add the rest on too.
CAI, Full Exaust, UDPs, I should be relatively close to 300RWHP.
That said, I will most likely do the instally myself, and have it tuned at a local shop.
The downside to this PI swap, is the computer will not adjust for this one. It will need tuning.
But then it "should" be a very nice street car.
But more on that as it develops.
97Bullitt
97Bullitt
El Paso, TX
I just want a good cam....
The trick flow cam is 1500-5000 powerband.
Which should be ok, since I don't plan to drag....maybe a few times, just to get legit 12s on my DD street car, and to spite my friend with a z06. But past that, I don't have the money or Rank to play "breaky" with my car.....
But a little lope in the idle would be nice :)
