4R70W leak any tips?
Hybridbird
Well I've been ignoring a pretty bad leak from my my auto 98 because it's always too damn hot to work on anything,and now it's bad enough, I can't ignore it any more.I got under it long enough to see the leak is coming from inside the bell housing, and it's leaking about 2 qts a week.I do notice that it leaks more right after it gets driven than after it sits, but it still leaks quite a bit overnight.I'm guessing it would need a new front seal, is there anything else I should be looking to replace while I'm in there? I will only have a day or two to drop the tranny do what I gotta do and have it back together so any tips from someone who has done this already would be a great help.
H
Hybridbird
No, it's definitely tranny fluid.Usually bright red clean fluid which only makes sense cause I'm dumping a few quarts a week through it, so I guess the only upside is I've probably got the cleanest running trans in town.
