4V cam swap???
watman02
who hear has done a 4v cam swap and what type of power gains have you seen/ felt. and was it worth it for the money. I've heard that crower cams has a cam kit that uses stock valves so I want to lean that way (so I dont have to pull the heads) what do you guys think???
duff daddy
you can degree your stock cams, put lt's on tune it and put a tubular K member and run low 12's all day in a mach.
96_SVT_Cobra
SN95 Supporting Member
Orlando
i have fr500 camshafts. their alright. they helped a lil. as for power increase i havent a clue cuz they were done when the motor was built with lower compression but it definitely didnt hurt. i will eventually go to custom grind tho or a stage 3 blower cams if i stay with the supercharger
duff daddy
advance them, but you need to find what the stock cams should at and go from there. You can prob get away with setting them like 2 * advanced. but they may not be even to begin with.
Shifty Powers
Where the wild goose grows
unless you really go with custom grinds with a FI setup or a high HP NA setup on these engines.. No one really changes cams because they dont usually do much for the 4v(specially from a cost effective standpoint).. A few terminator guys are actually running '97 cams(or 98) because they are supposed to be the most aggressive from the factory.
Listen to duff... LTs,tube K, and a nice ass tune will do you good man..
massacre
To the OP:
Stock centerline for all 4 camshafts is 114 degrees.
Advancing the intake cams 4 degrees makes decent power in N/A applications.
Also, like was said, many people swap '96-'98 Cobra intake cams, they have more duration from the factory than the Mach/Termi/MM cams. Supposedly worth ~15 RWHP BTW.
Shifty Powers
shame u talking the 97 cams in a boosted setup? Like i said there are quite a few Termi guys that have them in thier engines..
If your talking the timing #s they gave up there.. i dont know.. need them to chime in on that one
Shame302
Yep. I was just curious about the earlier cobra intake cams, 01 cobra heads and degree-ing them. I imagine they would be degreed differently for a boosted setup.
duff daddy
Shifty Powers said:
most likely.. need duff or someone to chime in on those specifics.. that is something i am unaware of
Eff that I dont know 4v junk spec's. If it was 2v I can do that but not 4 haha
Chris_Scott
I have COMP cams in my cobra and I absolutely LOVE them.
I swapped them in while I was putting on 03 heads, so it really wasn't any extra hassle for me, since I had to pull the engine regardless. Also I found them at a steal so I couldn't say no.
Anyways, while I do not know how much power I picked up from the cams alone...with stock 03 heads, stock 01 intake, and COMP #106400 cams, my car laid down 326rwhp with my ONLY bolt-on being an o/r x-pipe.
I got my car into the 370-380rwhp range by adding bolt ons and I am absolutely in love with hard the car pulls...with 3.27s it pulls hard ALL the way to the fuel cut off @ 7100rpms and still trapped 113-114mph all day long with the crappy 3.27s, 18" saleen replicas, and stock shifter.
The sound of my car at idle AND wot makes it worth every single penny.
