5.0 - Loud pop?
the5.ohh
Shaolin, NY
So this happened twice before. Once back in January i revved the motor and heard a loud pop, like it backfired, but not in the exhaust, from the engine bay.. Fast forward to last week, my dad and I were looking over some thing and revved the engine from the bay again to see if it would smooth out the idle, backfired loud from the bay again.. Today my dad drove the car and on the highway, he said at about 50 he punched it and it popped again.. What the ****? This car is starting to piss me off, I've repaired a lot since January..
Rallim
Bellingham, WA
^ First thing I was going to say. After getting mine back up together I was messing with the timing, advanced it a bit too far, it revved and ran great, but I got the occasional intake backfire.
the5.ohh
the5.ohh
Shaolin, NY
Funny thing is, timing was never touched as far as I know! Gonna have my mechanic check it out thursday since I don't have a timing light
Rallim
Bellingham, WA
Screw that, do it yourself it's one bolt, loosen it, play with it a little. I tried using a timing light once and we couldn't even get it to see the top of the crank anyways. Just turn it counter clockwise to retard it a tiny bit and see if it helps, one 13mm bolt holding the dizzy down.
the5.ohh
the5.ohh
Shaolin, NY
Honestly I'd rather not screw with it. Its my only means of transportation and I'd rather have him check it. If this semester was over I'd do it myself since I wouldn't really need the car. He won't charge me anyway lol
slow90coupe
Advance, NC
Good ole pushrods. Mine used to backfire out of the intake from time to time too. It's probably in the timing like stated above.
96gt4.6
UT
you can get a timing light for cheaper then paying a shop to do it one time, it is a very simple job. and like rallim said you can time it by ear really easy just loosen the bolt and turn it small increments till it sounds good with no popping.
the5.ohh
the5.ohh
Shaolin, NY
Yeah I know. He's not charging me to check the timing or adjust it.
96gt4.6
UT
i guess i didnt read your whole post on that one. also running a higher octane would be a waste of money for what you have done to your car there is no need for higher octane
the5.ohh
the5.ohh
Shaolin, NY
Yup its a waste. filled half the tank with 93 and didn't notice anything.. Lol
BlackStallion
Sardinia, Ohio
Vacuum leak otherwise if not timing like these guys are saying. I've had my '94 cranked up to nearly 14 degrees timing and no popping thru the intake.
the5.ohh
the5.ohh
Shaolin, NY
No vac leaks! So its gotta be the timing. I put on my stock ignition coil and it seems to run a little smoother
gofastbobby
Kalamazoo
When was the last time the car had a tuneup? I'm surprised you can get away with running 87 octane, mine spark knocks like a mofo with anything less that premium.
the5.ohh
the5.ohh
Shaolin, NY
Last summer. Plugs, wires, cap, rotor, iac.. Only put maybe 1500 miles on since than. Did an oil change about a month ago. Gonna get a new fuel filter and pcv valve soon. I always run 87, no issues. 93's a waste for mine
alexstang28
