5.4 Test Drive Video.
So did you get the COP thing all worked out? Obviously if the car is running... She sounds pretty good though.
330CubeGt
Thank Everyone!!!
I have the Stock Ignition on there right now with the coil packs i am just getting the bugs worked out of it then hopefully a Dyno Tune. Then i want to pull the upper harness off the car in about 2-3 weeks and cut it open and re wire it up on the bench for the COPS.Thanks again for the Info!!
330CubeGt
US Soldier(stang 98) said:
sounds sweet man. cant wait to see it done
Yea me either.Im going to make the drive to my buddies shop asap to get it on a dyno.
Spooling2Valve said:
sweet, gives me more motivation to slap this navi motor in :)
i bet the torque feels awesome.
Even with it untuned if you stab it in first rolling the front end come up hard and hold it there.so its deff torquey
Willis_98GT said:
have you thought about a speedometer gear to fix your speedo?
I have a 98 its same as a 99+ no speedo gears its eletronic. i just unplugged it because it was acting up and i have to fix it threw the computer.
mikey94gt
Dallas mustang has a box you plug in between the speedo output on the trans and the harness that will recalibrate the speedo, if you are concerned about it working. I used one, it works great!!
330CubeGt
Mabye it depends on what time of the year it was made ,idk.
My car uses the 99+ cat backs also.
