Slinger said:So i guess my real question is would the stock headgaskets and pistons be ok on 8 lbs?would it melt holes thru the sides of the pistons or blowout head gaskets?
Slinger said:Yes,the longblock will be stock until i can afford to build it the right way
Slinger said:Thank you,very helpful information.And i will be tuning mine myself.
Slinger said:By tuning mine myself,i meant adjusting the rise ratio in the fmu and changing my timing with the msd controller
Slinger said:i dont know how much it would make on 8 lbs.garrett t3/t4 .custom headers and all hotside,as well as pressure piping.dont know on intercooler or bov yet i was gonna use an 8 lb spring in the wastegate.i had the turbo given to me from my work.it was recently rebuilt,im a college student so i cant really afford the time or money of building the engine.i was gonna go with 30 lb inj. with a calibrated MAF.and msd ignition with a boost timing retard and thats as far as i know so far.i expect this setup to only make 300-350 hp if i were to throw out a wild guess. also ac and smog delete.im sure the stock rods and crank will be fine,but i don't know about the pistons or head gaskets
Right now my neighbor has a 93 GT with a stock motor and heads and just an intake running 8lbs all day with no issues. Only thing he ever has an issue with after 2 years is boost creep during the cooler days of the winter here in Florida. He has seen 10-11lbs a handful of times and popped a head gasket but that's it. Car rides out. Oh he does have a good tune on it and it makes 400 to the wheels.
Slinger said:yea, pretty much.i dont want to spend $1500 on an aem.i dont think it will be necessary.
Passenger said:a t3/t4 is vague, and tells us absolutely nothing about the turbocharger except its a t3 turbine, and a t4 compressor.
FWIW, a close friend of mine has a stock longblock 302, Twisted Wedge heads, Explorer intake, stock cam and is making 506whp/612tq running a Hellion turbo kit and a Master Power T70 with the .96 (or .98, I forget) hotside. Car is tuned on 10.2psi I believe.
Will your engine handle 8psi? Depends on the tune.
