8" rim
i_love_my_stang
how wide of a tire can you put on a 8" wide rim would a 275 be pushing it? its a 17" tall rim thanks
LaserRed5.0
I hear 275 is alright, but anything past that is pushing it. I am planning on putting 275's on my 17x8 bullitts. Good luck!
DSTRBD
Yes... why take the chance of breaking the bead and end up in a cRaZy situation !
GDTrumbo
Nashville, TN
Here's the way I go about this.
8" wide OEM wheel has a 245/45/xR-17. 245mm wide = 9.645" wide at the sidewall. So that's 1.6" wider than the wheel. For optimum handling per wheel width, this is as much width as you need. Above or below this the handling/wear will suffer somewhat.
275mm/45/xR-17 at the sidewall (275/25.4) = 10.827". This puts you at 2.8" wider than the 8" wheel width. With this you really should use a 9" rim. And so on, and so on.
10" rim, go for a 295/45/xR-17.
10.5" rim, go for a 305/45/xR-17
11" rim, go for a 315/45/xR-17
Another tidbit: The wider and the larger the footprint/contact patch on the ground the lower the lbs. per sq. inch on that footprint. You can gain grip with a wider tire, but go too wide and you wil start to loose grip. They still look cool though!
GT
I
i_love_my_stang
i was thinking about getting these guys
I
i_love_my_stang
i could do that, i just like the look of the wider tire, maybe ill just wait till i rebuild a 68 and put a fat tire on that
the sizes go like this
245/45-17
275/40-17
315/35-17
when you increase the width you have to drop the profile. Usually people run 245s on 8", 275s on 9", and 315s on 10-11"
GDTrumbo
Nashville, TN
245/45-17
275/40-17
315/35-17
Yea, your right. I was concentrating on the widths. The aspect ratio does need to drop as you go wider.
Nice catch!
GT
I
i_love_my_stang
cool thanks guys, i was trying to find stuff online about tire size and wheel width and i couldnt really find any good answers just wheel size calculators
