I have been asked in PM about cutting the dash, since other write ups apparently claim that you have to. My installation was done 3 years ago, so Im not 100% sure on everything that was done to it. I will take pics with the bezel removed, as I have plans to mess back there (installing bluetooth), but I will not do it this weekend. I will revive this thread when such pics/info about my install becomes available.
ttocs said:
the fit on the sides looks like it is off and the textures don't match at all. The bottom piece is cheap to replace and ensure everything matches unless you like it to look like an add on. Theres 3 different colors/textures of black there.
The fit on the sides is off because the 01+ bezel is designed to fit an 01+ dash, thus the bezel sits lower, causing the lower portion of the AC panel to be exposed more. Because it sits lower, there are a few millimeters at the bottom that are lower than they should be. It can be dremeled out or shaved, but I chose not to. If the screw tabs on my center console werent cracked off, it would sit right, and possibly shift the bezel higher. But find me a factory replacement red console.
As for textures not matching, I hope youre not talking about mine. The dash, console, and shifter are originals. Only the bezel is different. I had already planned on painting the bezel since my old one was already painted. Yes, matching a grey bezel with a black shifter would look weird, but everything matches.
My cars kinda torn up right now, so I cant give you any good pictures, but heres some that kinda include the bezel:
