94/98 v 99/04 rear ends
Pleasanton/Hayward, CA
Hey guys I may be swapping out my rear end for an 01 rear end with 355s. I know there's some differences but wanted expert advice. Isn't the new edge rear end a bit longer than the sn? And by how much exactly
g36 monkey
Orlando, Fl
If I remember correctly it is a total of 3 inches longer, 1.5" on each side
fran5o
Not that much wider, 1.3" wider total, so under 3/4" each side, I believe it's 3" wider then a fox rear ( 86-93)
Should be a direct swap otherwise.
Thomas_W
Capon Bridge, WV
I believe the axle bolt holes for the lower control arms are a different size as well (14mm instead of 12mm)
bwiz760
