Frank.JD.Perez
Hey guys I may be swapping out my rear end for an 01 rear end with 355s. I know there's some differences but wanted expert advice. Isn't the new edge rear end a bit longer than the sn? And by how much exactly
If I remember correctly it is a total of 3 inches longer, 1.5" on each side
Not that much wider, 1.3" wider total, so under 3/4" each side, I believe it's 3" wider then a fox rear ( 86-93)If I remember correctly it is a total of 3 inches longer, 1.5" on each side
Yea sorry for the bad info guys. I got some stuff confused.
I believe the axle bolt holes for the lower control arms are a different size as well (14mm instead of 12mm)
1.5 wider. Looks better
Sent from my LGLS991 using Tapatalk
