94 GT 351 vs 95 GT TURBO.....opinion on who will see tail lights?
G
GREG@SN95
Guest
ok...
You are both pretty much equal so far as power, and assuming you are equal in driving skills, the car with the better suspension, better traction, and less weight... will win...
G
GREG@SN95
Guest
95Grandtouring5.0 said:
Look at it this way. He will be playing catch up that is for sure. He will probably roast the tires, while you won't so much because you gotta wait for boost to build. You'll have the better start then your turbo will be kicking in. If I had to vote I'd say you.
lol... no... he shouldn't have to wait for boost... if he does, his turbo is way too big...
voidfinger
stang94X said:
horsepower number means shit in my book, ive seen low power numbers run fast 1/4 mile times, its all on the motor and car setup, how is the power curve, what rpm his motor going to peak at, what are the torque numbers and what kind of power curve is it, what kind of tranny do you have, whats his, is he useing a stock built aode or 5speed from the car, if he has an automatic then what stall is it, a mild 2400 stall or more of a street strip 3000-3200 stall or even higher, is he going with an aftermarket 5 or 6 speed, is he going to a c4 or c6 and how is the tranny built, is it stock,just a shiftkit or is it built for racing, what rear end do yall have, does he have a stock rearend with gears or is it a aftermarket posi unit with gears and what gears do you both have, it all come into consideration with what tranny, rear end setup, and tire combo yall have, the gearing of the tranny and rearend gear with the right height tire can determin a whole lot, and suspension, you have stock spring, struts and shocks or aftermarket, are they lowering springs for cornering or are they a drag spring, are the stuts shocks stock or setup for handling or dragracing, what does the car weigh, is it a stock weight car or do yall have a bunch of shit ripped out of it, do ya have stuff that adds weight like subframe connectors, roll bars, aftermarket sway bars, and other types of bracing, or even stuff like having a system in the truck can weigh a bit, i mean my 94 gt automatic convertable now weighs 3160 pounds and me having that weight takes off a bit of time from the stock weight, the whole setup comes into play, not just horsepower numbers
I would be very interested in learning how you got that car down so much weight??? send me a pm please. need some help on my 98 gt vert :)
Stopsign32v
voidfinger said:
race yet???
:rollinglaugh: Fuck no! He doesn't even have his motor together yet. Then he has to do the 351 swap into the GT. I was just asking this thread because his ignorance got ahold of me. Anyways it doesn't matter, I'm building a short block right now to put in my car and it will probably be done before his motor is done. Then I plan to turn the boost up alittle. ^-^ However I'm gonna first run him at low boost setting and let him think he is doing good. Then I'm gonna bump her up and :eek:uttahere:
voidfinger
Stopsign32v said:
voidfinger said:
race yet???
:rollinglaugh: f**k no! He doesn't even have his motor together yet. Then he has to do the 351 swap into the GT. I was just asking this thread because his ignorance got ahold of me. Anyways it doesn't matter, I'm building a short block right now to put in my car and it will probably be done before his motor is done. Then I plan to turn the boost up alittle. ^-^ However I'm gonna first run him at low boost setting and let him think he is doing good. Then I'm gonna bump her up and :eek:uttahere:
Don't count your chickens until they hatch buddy.
