95 5.0 Ignition pick-up coil replacement
At1Maverick
Las vegas, NV
Hey all, being on a budget, I opted to replace just the magnetic pickup coil inside the distributor. I've narrowed down the no start/hard starting issue to this. I was wondering if there was a video of how this is done. I remember doing a fox dizzy before but wasn't sure if I did it the hard way. I practically tore the dizzy down to the core, so the gear came off, and the housing came off.
I kinda heard the it's possible to take the plate where the rotor sits on and take the pick-up from there. Anyone done this before? Any help would be appreciated. Thanks!
CC'S95GT
Hampton ,Ga.
Same as a fox dizzy.
Pay close attention to the bushings/bearings that the inside the housing. I've had them worn to the point that the reluctor wheel hit the PIP.
At1Maverick
At1Maverick
Las vegas, NV
Got it done, yeah, I found there's quite a bit of up and down movement on the dizzy, i tried looking up specs, is there such? But the car fires up now, it still takes a couple of tries, but it does, I guess i'm gonna go ahead order a distributor as soon as possible.
Would excessive wear on the bushing cause the hard starting as well? I've tested the coil, and it's good, and although I'm going to be doing plugs and wires probably tomorrow, I trying to think of other thing that might be causing the hard starting
CC'S95GT
Hampton ,Ga.
that's a bangin deal for a new dizzy.
As for the hard starting, I always start with the tune up first. What is the timing set to? 10* is base but most of us run about 12*-14*
At1Maverick
At1Maverick
Las vegas, NV
yeah. that's what i figured, the easy, simple things first before going neck deep. The timing I set at 10* cuz I though they'd check during emission testing, I've set my older foxes at 14* before and I liked the little difference it made.
RevJon
