95 Cobra Upper Hardware
BillG
Hickory NC
Anyone know where I might be able to find the proper mounting bolts for this.
throttle-body-jpg.1284
Not sure if what's being used is right and not wanting to mess up the manifold if it's not. So trying to find factory or proper replacement. Thanks so far for all the help and info so far on this journey.
BillG
BillG
Hickory NC
I thought the cobra and GT mounting hardware were the same?
apparently I'm missing something with these bolts I have cause I can't find a winning combo out of the 4 long bolts I have to bolt the intake plenum on and there is only 4 possibilities cause the rest that are needed are short ones for sure. Why I like doing my own tear downs LOL.....
RAU03MACH
NEW MEXICO
I believe that they are all the same gt40, cobra and tubular gt40 , mine changed over with no spacer .
the only thing is how thick you want the spacer
then length changes
BillG
BillG
Hickory NC
then length changes
That's the thing. I don't think this one has a spacer or at least its not present at moment. Is there suppose to be a spacer there? Cause that could be why I'm having issues.
Stock there was no spacer. If your using tall valve covers it can be an issue if the upper hits the valve covers. If that is the case then the spacer is needed, anything less then 1/2" will clear the stock hood but you will loose the use of the strut bar. Spacer kits come with hardware and its also good to help separate the upper/lower to keep the upper a little cooler.
