95 GT and Cobra Throttle bodies.....
OpenRoadRacer
Is there a difference or are they the same?
I have my stock TB I'm looking to get rid of & would like a little insight for any questions that may come up.
I think they are the same....
I'm pretty sure only the '93 Cobra was 65, in '94 they went down to 60mm; and i thought the GT was maybe 50 or 55 or something...
SvtBlack95
hmm i wonder if thats what it is sleeper.... i would have to check that out cuz seems alot of people seem to hear different all the time ???
G
GREG@SN95
be carefull when buying a new TB
they are like carbs
the slightest increase or decrease in diameter could affect power effeciency etc for the better or the worse...
O
OpenRoadRacer
95 Sleeper said:
I believe the 94-95 Cobra's are 63MM.
hmmmmm i thought they were 63MM too. but i didn't know if the GT ran the same one or not.
looks like i will research this a little further and post up what i find out.
thanks folks!
O
OpenRoadRacer
ok, here is the answer.....
Cobra Specs
Here is a list of items that are unique to the Cobra vs the GT (94-95)
If anyone has anything to add to this list feel free to e-mail me.
Engine/trans
The Cobra engine was under rated at 240bhp from the factory campared to the GT's 225bhp and was only available with a 5 speed and 3.08 rear end gears.
Cast iron GT40 heads
Cast aluminum Cobra intake manifold
Crane 1.7 rocker arms
24lb fuel injectors
Cobra specific ECU (computer)
"Cobra" stamped valve covers with build sticker and signature
Engine oil cooler
Front mounted power steering fluid cooler
Lightened flywheel
Phosphate coated transmission gears
Overdriven waterpump pulley
Cobra specific camshaft
Cam specs: Duration: 227°/Intake & 270°/Exhaust
Lift: .485/.485 Intake/Exhaust
Lobe separation: 118.5°
Suspension/Brakes
13" Front brakes
11.65" rear brakes
"Cobra" embossed front calipers
Cobra specific brake booster
Cobra specific rear sway bar
Cobra specific shocks/struts/springs
K-member that is slightly stiffer than the GT's
No strut tower brace
Interior
Steering wheel center / Airbag cover embossed with "Cobra"
White faced gauges
160mph speedometer
"Cobra" embroidered floor mats
Exterior
Cobra specific 17" wheels
Cobra specific rear spoiler with integrated 3rd brake light
Cobra specific front bumper cover
SVT emblem on decklid (95-up, not on 94)
Cobra emblems on front fenders (no 5.0L emblems)
"Crystal" (clear) headlights
Round cobra specific foglights
Other info:
The 94-95 Cobra (and GT) came with a 60mm throttlebody, not the 65mm alot of people believe it to have. The 93 cobras came with a 65mm.
Although the 94-95 Cobra came with 24lb injectors it still uses the same MAF (mass airflow meter) as the GT. The Cobra specific computer compensates for the 24lb injectors.
Many people say the Cobra came with underdriven pulleys but from what i've heard it only has a Cobra specific overdriven waterpump pulley. Even if they are slightly underdriven they are nowhere near the same as real underdrive pulleys.
94-95 Cobra trivia information (posted on the SCOA bulletin board posted by "Dano" from the SVT cobra recognition guide)
1. '94 was the first year of the front facing Cobra snakes!
2. These two years were the only ones to have the "Crab Claw" spoiler, with built-in LED brake light! (The GT's stop lamp was mounted on the rear decklid)
3. Only three colors were offered:
a. Rio Red Tinted Clearcoat
b. Crystal White
c. Black Clearcoat
4. The '94 Indianapolis 500's official pace cars were GT's converted to Cobra specifications.! They were five converts, with a four-speed AOD automatic trans! The actual "Pace Car" was driven by Parnelli Jones. 1,000 of these replicas were built, for sale to the public! If you have a '94 convert, it's an Indy 500 replica, with all the special badges & markings, and it's red!
5. The easiest way to tell a '94 from a '95:
a. The '95 has an SVT badge on the trunk lid.
b. The '95 has a vertical flair attached to the front of the rocker panel extension.
6. ALL '94 Cobra converts were Rio Red Indy Pace Car replicas.
7. ALL '95 converts were black.
8. The '94 convert tops were saddle color, and the '95 convert tops were black. No other color combinations were available!
9. '94 and '95's converts came with saddle interior.
**source**Click here
Cwacaser
