95 gt - v2 s-trim, what heads, cam, ignition?
94kingcbra
Before you get heads, pick your cam. Then, choose the proper spring rate for that cam. This way you can get the heads assembled with the right springs for your cam. Then, you'll need an adjustable push rod to measure proper length once you have the cam in, and heads bolted up. My vote goes to AFR 185's, and a cam with low overlap but good lift. Good luck.
get the 165's they are enough for your 302 and call Ed curtis, have himgrind you a cam for your application
IIRC glueyes is running 165's on his 331 @ 500 ish hp.
