97 Cobra No Start
uncltrvlnmatt
Pa.
Car cranks but does not start. I have no spark at the coils. Everything else works. Drove it the other day ran fine, parked it in the garage now nothing.
Ideas?
U
uncltrvlnmatt
Pa.
No scanner to check with
66 is in limbo at the moment. Hope to get back to work on it soon.
white95
Apex Junky
Admin
Prairieville, LA
Crap Matt, that sucks.. Loose grounds for ECU? A wire could've corroded and not making a good connection @ the coil? (Not a 4v guy but can only be so many things) You can take a multimeter and test for DC voltage @ the connector feeding the coils.
U
uncltrvlnmatt
Pa.
Just did that 11.9 volts at the coil hot wire with battery ground, and 11.7 volts at the coils through the coil ground. Yet no spark. I find it odd that 2 coils would go bad just like that at the same time. But shit does happen, so we will see.
