98GT DRINKING OIL!!!!!
98GTnSC
like the title states my 98GT stock. is DRINKING oil! like bad. just went outside and checked it and there was barely any on the stick. i added about a half quart but yeah it wont last long @ all. im using Mobil 1 Synthetic 10W-30 high mileage now. car only has 80,000 miles on it but since its been drinking oil then i figured id try high mileage, but with NO luck. anyone know what could be causing this? thanks
duff daddy
Your car doesnt "Drink" it, it either gets burned or leaked out(to the ground or another fluid sorce. You need to see where is it going. Is it some ohw getting in to the coolant? or is it leaking under the car? Next see if you let the car idle for a good 10-15 in will it puff smoke, or if it smokes after you get on it real hard. This is the diagnosis step so you need to see where its going.
duff daddy
oh on another note, FACTORY spec is 1 quart of oil used per 1,000 miles of use so if you go 3k it is acceptable to see it own 3 quarts ***this is factory spec*** but if you go over the 3k mileage, then expect to see the oil down some.
98GTnSC
thanks alot man for getting in here so soon. but there hasnt been any oil leaking under the car or anything and she smokes a little out of the exhaust but none under the hood that ive noticed. but i figured it may be due to the O/R Xpipe
duff daddy
Your exhaust won't cause your engine to burn oil, but you sound like you may be burning it. The amount, 1 quart per 5k, your fine dont worry.
marq.fcb said:
I have similar problem, my 95GT "drink" 1L per 500miles without leaking or smoking
You have issues but you just dont see it smoking. My car was using about the same per the same mileage, You either have bottom end issues or valve seal/guide issues(if not leaking out)
marq.fcb
Croatia(Europe)
my car has been parked in the garage for 4-5 years
wm23n1
My 01 camaro z28 drank oil like crazy too. I thrashed that car from day one when I bought it new. Guess the 100 shot didn't help it much either!
marq.fcb
Croatia(Europe)
Duff Daddy said:
hahahah alright then yea you definaly could have some seal or ring issues then
whether the problem is large or small? per year I make 2-3k miles, so if that problem is small i don't wanna open my engine.
is that ok?
98GTnSC
id go ahead and fix the problem dude. even if it is that small. i may be doing the same thing.
1Sic98gt
i had the same problem with my 98. turns out i had a blown head gasket.. which in turn helped me do the P.I. swap.
98GTnSC
well i just changed the oil 2 days ago so we'll see how long it lasts. id like to do the P.I swap but only when i have the $ for it.
