99-04 Rear End in 94-98
Tony Corley
It bolts in, is 3/4" wider per side. The lower bolt holes are larger, so you will need to change the rear bushings in your lower control arms, or use lowers from a 99-04. It fits, but I don't see any advantage too it. More rotating weight and more unsprung weight, not to mention changing the front and rear track width. I'm actually going the opposite way and putting Fox length axles in my '94, and changing the front lower control arms to Fox width. Cut down on unspung weight and allow a better offset on the rear wheel, and tuck the fronts under the car more.
RichV
CO
But you want track width for better handling, no? That is a benefit, same with using wheel spacers to maximize the width.
Tony Corley
I am a drag racer, so I always think along those lines. But even at that, why not run the shorter axles for less reciprocating weight, and just change wheel offset to adjust track width?
