A/C not blowing cold?
02GT
Greenville,SC
The A/C is blowing just not blowing cold....can I get one of those do it yourself cans with the hose and gauge for 30 bucks or do I need to get it fixed by somebody? If its lost r134a then I probably got a leak but i figured i'd ask.
red95r
SUGAR LAND TexSuhZ
I'm going through the same thing, loosing freon. get a can with a dye in it. then buy a LED pen light to find the leak. go from there.
Be forewarned if you use a can with a leak stopper you will eventually have a bigger problem.
Steve@CJPP
Harrisburg, PA
Try a do it yourself refill kit, then use your air as much as possible for the next week or so and see if it stays cold, if it doesn't then your are going to probably have to have it looked at to see where the leak is. I know I can refill mine and it's good for about two weeks then it's crap again. Don't use a sniffer do the dye system, a little pricey but you'll get more accurate results.
