A/C removal
chrajohns0
took out the lines last week end, going to get the pump out this weekend. should i take out the condenser? or just leave it there so that it takes any rock and the rad does not. also what about what is in the cab. should i take the box out? i am assuming that there is something in the cab with the lines that run in there. thanks.......
94 DropTop
how did you plug the lines going into the car. how did you discharge the system.
C
chrajohns0
the system was dead, nothing in it when i got the car. and i have not plugged the holes. i am taking it that i should?
Mr. OAM
Since the only performance gain in removing the A/C system is the loss of weight you should remove the condenser and the evaporator that is in your duct system, though it may be a nightmare to get to it, for maximum effect of the modification. Since the compressor is so much lighter than the compressor of the 60's and 70's the weight reduction is not quite as significant.
I trust when you removed the lines that you also removed the accumulator?
Steve
94 DropTop
when do it i plan on taking out everything in the engine bay. everything behind the dash can stay for all i care.
